EKX powered speakers with Drive Rack
Im using powered tops and powered subs with a drive rack and here's my issue. I'm bypassing the crossover on my tops which are the EV EKX 12p which is working out fine but I can't bypass the crossover on my subs EV EKX 15sp, I don't like the fact that I can't bypass my subwoofers internal crossover and I'm still using a x over on my driverack as well. What should I do in this situation? My Subs don't sound Right at all.
Set the DRPA's lows filter as 20hz BW24 - 500hz LR24.
Set the sub's lpf to 100hz,
Set the DRPA's highs filter to 100hz LR24.
Of course, you could also send a full range signal to the speakers and let their x-overs handle everything. I would be a cleaner set-up, but you gain more control (more PEQs and output band gains, more limiting) using the 1st example.
