How to set 260 when more then 9 band peq is needed?
Hi from newbie
Wonder if I could make configuration on my driverack 260 for Seeburg Acoustic line K24xov louspeaker tops...
I found prefered settings on their official web page, as follows:
#K24xov Flat
fullrange
gain +0dB
phase nor
power 4R 900W 2400W 32dB
rmstime 500ms
peaktime 50ms
hpf BW12 100Hz
peq 90Hz Q1.5 -6dB
peq 315Hz Q3 -4dB
peq 380Hz Q3 -8dB
peq 750Hz Q3 -6dB
peq 1000Hz Q4 -3dB
peq 1600Hz Q2.5 -2dB
peq 2500Hz Q6 +6dB
peq 3400Hz Q6 -1dB
peq 10000Hz Q5 -4dB
peq 16000Hz Q4 +6dB
hshelf 12 4000Hz +1dB
As you can see, there are 10 peq points, hpf and hshelf.
Driverack 260 is 9 band PEQ pre-crossover.
What do you suggest?
Thanx in advance
#K24xov Flat
fullrange
gain +0dB
phase nor
rmstime 500ms
peaktime 50ms
hpf BW12 100Hz
peq 90Hz Q1.5 -6dB
peq 315Hz Q3 -4dB
peq 380Hz Q3 -8dB
peq 750Hz Q3 -6dB
peq 1000Hz Q4 -3dB
peq 2500Hz Q6 +6dB
peq 3400Hz Q6 -1dB
peq 10000Hz Q5 -4dB
peq 16000Hz Q4 +6dB
Thanx in advance
The 10th can be set in the post-x-over PEQ section. You have 4 filters there.
The high and low shelves can be set in the post-x-over PEQ section or with the x-over filters.
You didn't mention if you re using subs, but it appears that you are with the 100hz hpf. That may change my recommendation.
I am using subs too:
#KSub1502
sub
gain +6db
phase nor
power 4R 1600W 4800W 32dB
rmstime 1000ms
peaktime 100ms
hpf BW12 45Hz
lpf LR24 100Hz / 120Hz /140Hz
peq 45Hz Q2 +3dB
peq 80Hz Q2 +1dB
peq 200Hz Q0.7 -5.5dB
peq 270Hz Q5 -3dB
1: Set up the x-overs.
Sub: 45hz BW12 - 100hz LR24
Tops: 100hz BW12 - 18khz BW12 or similar to suit.
2: Post-x-over PEQ (low)
Select "Bell" and set the 4 PEQs for the sub. (45 - 270)
3: Post-x-over PEQ (high)
Select "High shelf" and set the 3 lowest settings to bell filters 1, 2, & 3. (90, 315, 380). Filter 4 is the shelf. Set the 4K shelf here. I interpreted the 12 as the slope.
4: Pre-x-over PEQ
Set filters 1-7 for the 750 - 16K settings.
That leaves 2 filters for you to season the sound to your own tastes.
