***** Output loss repair procedure *****
This problem is indicated by the output meters indicating signal, but no output (permanent or intermittent).
The output relays' solder points are fragile.
Here is the repair for this common problem.
See the images and instructions below.
Reportedly, this is the repair bulletin from DBX.
Is this hardware design flaw only on certain Venu360 models or production ranges? I have the newer Dante model, but I am uncertain if mine is also affected or not.
Below is from the PSW forum.
Quote from: Mike Caldwell on Yesterday at 08:40:27 am
Is that problem for all 360's of just a certain production run / serial number range?
Technote does not give a range but says "Apply to service units only" (As opposed to "Update stock and service units" or "Information only").
It doesn't say in the post but I take it that the red and black wires were originally in the female part of this connector. Is that right?
It's hart to believe that such a part could come off. The nylon part is basically a big "hook". Does it actually come apart or is it just a lousy connection?
