Venue 360 crossover settings
I run the sound at my church, and I need help setting up venue 360, that I just bought for my church. Most of our equipment was donated to us. I have 2 peavey SSE 15 tops in stereo powered by a QSC USA 400 amp. I have 2 behringer b1800 subs powered with Behringer ep2500 in mono.
I was looking around at the specs online and reading FAQ in this forum. I'm thinking the amp on the tops need to be upgraded as it is underpowered. The church has been running this setup for years now
. However, is there like a "safe" crossover setting for this setup until there is a new amp donated or I can save enough money to upgrade myself.
The recommended crossover is 80-150hz. According to manual I found online.
I was thinking something like:
Subs: BW 18- 45 hz
LR 24 120 hz
Tops: LR 24 120 hz
Thanks for your help.
Subs: BW 18- 45 hz
LR 24 120 hz
Tops: LR 24 120 hz
Thanks.
I was using pink noise from laptop via FireWire on channel 1 of mixer. I got the mixer to clip in red on main output meters with master fader at unity. Then on venue360 I matched the analog input clip limit to +24 dBu on all inputs per studiolive 24.4.2 max output spec. The inputs of venue 360 were clipping at same time as mixer. This were I think I messed up. I might have forgot to check gain structure between venue360 and amp. The output clip levels were set to +12 dBu. I then turned up attuenators until they clipped on amp. Then set limiters.
Perhaps I need more power to speakers. My power to them is pretty low. I just bought a new amp for mains. QSC GX5. 500w @ 8 ohms. For mains rated at 500w program. Then I plan on using the ep2500 for subs daisy chained in bridged mono. Hopefully that would work.
I will try that Monday. I'm setting up new amp then.
How do you setup gain structure monitors?
Gain structure is gain structure. It is the same for everything, unless dealing with powered speakers.
