Preset Questions
I'm very new to pro audio and have a fairly basic setup right now
Yamaha MG166CX-USB mixer
QSC PLX 3102 power amp
Behringer Eurolive B215A powered x2
Yamaha CM15V monitors x2
I'm considering investment in the PA2 or even the Venu360 since I don't have anything else in the rack right now.
Before I make the investment, I'm curious if there's existing presets within the Driverack software for my cabinets. Can someone with a unit advise?
The PA2 does have some limitations when processing 2 completely different inputs (mains and monitors, for example). AFS, compression and the pre-PEQ can't be separated. The AFS is that state would be a deal breaker for me. The 260 is much better suited for that. The 360 is as well and also allows either stereo mains and 1 mon mix, or mono mains and 2 mon mixes.
Youtube is very helpful. DBX has an official tutorial. http://dbxpro.com/en-US/training
The link is not opening, but you might cab call tech support and see if they is a different link.
Her is the software. http://dbxpro.com/en-US/softwares/drive ... -2-windows
hdi pcb
