DRIVERACK PA2 - CROWN XTi4000-XTi2002 - JBL EON 305 WIRING
Hi,
I have the following :
Amplifiers
Crown Xti 4000 (1)
Crown Xti 2002 (2)
InterM M1000 (3)
Speakers
JBL EON 305 Passive (4 speakers) (4)
Dap Audio Woofer (not sure about the model) (5)
and of Course DBX DRIVERACK PA2
(6)
I want to make a correct wiring and setup I read the manual but I have some basic questions as far I am not somuch familiar with sound setups
*Firstly EON 305 is a 2-way speaker so the only way to connect them is to use both MID & HIGH over one Amplifier right ?If not , How can I make a Full Range setup (wiring) ?
**If yes , then I just need a pair of speakon NL4 cable to run from amplifier to the speakers...
I am using parallel connection between the 2 pairs of JBL EON 305 Passive(4)
***I will probably use the 4000(1) over the MID & HIGH and the 2002(2) for my woofer
****Is there any way to make Eon 305 in Full range setup ? Maybe without paraller because eon 305 have 2 inputs ?
EON 305 DATA SHEET
https://www.jblpro.com/ProductAttachmen ... EON305.pdf
Amplifiers
Crown Xti 4000 (1)
Crown Xti 2002 (2)
InterM M1000 (3)
Speakers
EON 305 DATA SHEET
If you want to run your 4 JBL speakers, 2 each paralleled on each side of the Crown 4000 amp, as highs, and your 1 DAP speaker on the Crown 2002, then this is the connection.
PA2 Hi (L) ----> 4000 (L) ----> JBL #1 ----> JBL #2
PA2 Hi (R) ----> 4000 (R) ----> JBL #3 ----> JBL #4
PA2 Low (L mono) ----> 2002 ----> DAP
(I don't see how the 1 DAP speaker will match up well with the 4 JBL speaker,)
Without info or specs on the DAP speaker, I can't recommend x-over settings.
Use the 2002 for High
Use the 4000 for Mid
Use the 1000 for Low
To get Full Range setup
Let's put the paraller on the side and think it with a pair of speakers
The speakon cables has 1,-1 , 2,-2
I split the speakon cable in 2 parts
the 1,-1 will be at the 4000 MID
and the 2,-2 will be at 2000 HIGH
so the cable is like that
SPEAKER 1,-1,2,-2
>>> 1,1||||2,-2 AMP
I attached a photo
My question is If that split I did with the speakon is correct
To bi-amp these speakers, the internal x-over must be eliminated and connections made straight to the horn and low drivers. You said that you were not good at sound stuff, so you are over your head on this. Bi-amping is for advanced knowledge levels. Without tuning parameters (which you don't have, because JBL doesn't offer them for a passive-only speaker) the speaker will never sound as good as the passive x-over will give you.
So I will connect the 4000 to speakers
And the woofer to the 2000
Both over speakon nl4 without splitting
Are there any special parameters I have to do at the dbx I had some issues with the tweeters the wiring was a mess ... now I am waiting for the speakers because I send them to replace the faulty tweeters
If you are familiar with the dbx setup please let me know in order to help me if is possible ...
Thanks for your time !
Technical Info :
Components:
Woofer: PA-18100220JM
Nominal Impedance: 8 Ohm
RMS Power Rating: 500 Watt
Program Power Rating: 1000 Watt
Peak Power Rating: 2000 Watt
Frequency Response: 50 - 250 Hz, -3 dB.
Frequency Range: 40 - 300 Hz, -10 dB
Efficiency: 103 dB/W/m Half Space
Dimensions: (LxWxH) 515x560x700 mm
Net. weight: 45 Kg
that's my woofer
As for the input I have Pioneer DJM-900NXS
http://www.pioneerdj.com/en/product/mix ... /overview/
If there is any place where can I read about dbx setup rather than manual and some official videos simply let me know !
I am not familliar with sound etc. but I want to learn
viewforum.php?f=60
Youtube it your friend for driverack videos.
I'll have to think about setting your x-over.
some parts of the old wires where naked and i believe that was the reason .....
as I said I want the best We can
What kind of events will you be using this for?
Will the music be played VERY loud?
Will you be driving the all the Eon 305's to their full volume capacity, or at least to their amp's full capacity?
I ask, because a single 18" sub will not be able to balance to 4 of those Eons, unless the Eons are turned down quite a bit.
Last time I measure the dB was around 120 to 150
For now because I dont want the amps to fail I have decrease the level in order to avoid clipping but as I see the amps leves should be full and the dbx manages them I attach a photo of my current amps levels
https://1drv.ms/u/s!AmanhecHJTk-gyvAoc63zotnBpX0
some detaisl about what you see
the 2000 and 4000 are bridge and connected to the eons
the 1000 is for the DAP
I am using them like that and never amps fail or clip and just to let you know I started all the in order to make my audio better (wiring,settings balance limiters everything needs to be resetup)
yes I want to be able to play with their full volume capacity
Keep asking me for anything you want even if you want details etc. and again I really thank you for your help!!
For you, giving them 250w is the safest amount of power, and your speakers will last for a really long time. Giving them 500w is somewhat safe, but damage may still occur, due to the typical DJ music.
The difference in output volume between 250w and 500w is only 3 db. 3db difference in volume is very small.
Power compression in the speaker is also a factor. There is a point where more power (watts) going to the speaker does not equate to an increase in sound, only an increase of heat.
Having said that, this is what I recommend, based on your use and set-up.
1) Do not bridge any of your amps.
2) Use the 2002 for all 4 of the Eons.
3) Use the 4000 for the DAP.
4) Set up the DRPA2 for Stereo with mono sub.
5) Set up x-over.
Highs: HPF - 55hz LR24
Lows: HPF - 40hz BW18 LPF - 80hz LR24
This overlap is not ideal, but may be necessary because of your limitation of 1 x 18" sub vs 4 Eons. You can also try slowly increasing the 55hz up to 80hz, listening for the best sound as you move it.
Your gear:
XTi 2002 - 800w @ 4 ohms (2 Eon 305's paralleled on each channel = 400w each)
XTi 4000 - 650w @ 8 ohms (DAP sub on one channel = 650w)
Any suggestions ?
