DriveRack 260 with EV TX1152 and EV TX1181
Hi guys
Need some advice ... Even if it's just temporary.
We had a good friend (sound pro) setup our DriveRack 260 a few months back.
Since then, we've teaked it here and there.
But then a few weeks ago I deleted the user group and we lost ALL the settings.
Yeah, I'm still kicking myself for that.
Anyway, we've managed to get the system sounding pretty decent, using an old preset as a starting point.
But for the last few weeks, our kick and bass drop out the mix completely at times, then slowly start coming back.
My guess it's a limiter / compression setting that needs adjusting.
Here are the Crossover, EQ, limiter and compression settings we're using.
Would appreciate any advice if there's anything glaringly wrong.
Jakes
DBX DriveRack 260
Tops:
2 x EV TX1152
Amp: Crown XLS602
Subs:
2 x EV TX1181
Amp: Quest QA2000
Crossover Settings:
Top L+R:
LPF: 19.6kHz
Slope: BW 24
HPF: 121Hz
Slope: BW 24
Gain: 0.0dB
Subs:
LPF: 121Hz
Slope: BS 24
HPF: 27.8Hz
Slope: LR 12
Gain: 1.0dB
EQ Settings:
Top L+R:
PEQ: On
Flatten
Bell
F1: 707Hz
G: -2.5dB
Q: 0.175
F2: 5.04kHz
G: 3.5dB
Q: 0.939
F3: 2.45kHz
G: 0.0dB
Q: 0.939
F4: 5.04kHz
G: 0.0dB
Q: 0.175
Subs:
PEQ: On
Flatten
Bell
F1: 20.9Hz
G: 1.0dB
Q: 0.433
F2: 125Hz
G: 1.0dB
Q: 0.433
F3: 728Hz
G: 0.0dB
Q: 0.939
F4: 5.04kHz
G: 0.0dB
Q: 0.175
Compression + Limiter:
Tops:
Compression:
Comp: OFF. Auto: ON.
Overeasy 2
Threshold: -6.0 dB
3.0 : 1
Gain: 0.0 dB
Attack: 0.3 ms
Hld: 116 ms
Release: 45.0 dB/s
Limiter:
Limiter: ON. Overeasy 2
Threshold: -3.0 dB
PkStop+: OFF. Auto: ON
Overshoot: 6.0 dB
Attack: 0.1 ms
Hld: 50 ms
Release: 150.0 dB/s
Subs:
Limiter:
Threshold: +4.5 dB
Overshoot: 6.0 dB
Attack: 75 ms
Hld: 50 ms
Release: 75.0 dB/s
Jakes
DBX DriveRack 260
Tops:
2 x EV TX1152
Amp: Crown XLS602
Subs:
2 x EV TX1181
Amp: Quest QA2000
Crossover Settings:
Top L+R:
LPF: 19.6kHz
Slope: BW 24
HPF: 121Hz
Slope: BW 24
Gain: 0.0dB
Subs:
LPF: 121Hz
Slope: BS 24
HPF: 27.8Hz
Slope: LR 12
Gain: 1.0dB
EQ Settings:
Top L+R:
PEQ: On
Flatten
Bell
F1: 707Hz
G: -2.5dB
Q: 0.175
F2: 5.04kHz
G: 3.5dB
Q: 0.939
F3: 2.45kHz
G: 0.0dB
Q: 0.939
F4: 5.04kHz
G: 0.0dB
Q: 0.175
Subs:
PEQ: On
Flatten
Bell
F1: 20.9Hz
G: 1.0dB
Q: 0.433
F2: 125Hz
G: 1.0dB
Q: 0.433
F3: 728Hz
G: 0.0dB
Q: 0.939
F4: 5.04kHz
G: 0.0dB
Q: 0.175
Tops:
Compression:
Overeasy 2
Threshold: -6.0 dB
3.0 : 1
Gain: 0.0 dB
Attack: 0.3 ms
Hld: 116 ms
Release: 45.0 dB/s
Limiter:
Threshold: -3.0 dB
Overshoot: 6.0 dB
Attack: 0.1 ms
Hld: 50 ms
Release: 150.0 dB/s
Subs:
Limiter:
Threshold: +4.5 dB
Overshoot: 6.0 dB
Attack: 75 ms
Hld: 50 ms
Release: 75.0 dB/s
Thanks so much for the advice. Really appreciate it.
I'm a novice so just some further questions:
Compression: Compression is generally a bad idea. If used, it should be really minimally
Overeasy 2
Threshold: -6.0 dB
3.0 : 1
Gain: 0.0 dB
Attack: 0.3 ms
Hld: 116 ms
Release: 45.0 dB/s
You mentioned "if compression is used, it should be minimally. What adjustments would I need to make?
Should I make it Comp: OFF. Auto: OFF as well?
Limiter: The difference between PkStop+ on & off is... on is a peak limiter and off is RMS. You have to choose what is more important to you and you protection scheme. Using the auto feature may be your problem. It adapts throughout the show, and has been shown to introduce unwanted artifacts (noise).
Should I set this to: PkStop+: ON. Auto: OFF ?
Threshold: -3.0 dB
Overshoot: 6.0 dB That is a lot of overshoot. What could I set it to?
Attack: 0.1 ms
Hld: 50 ms
Release: 150.0 dB/s
Subs:
Limiter:
Threshold: +4.5 dB
Overshoot: 6.0 dB Again, a lot of overshoot, particular in RMS mode. What could I set it to? And should it be PkStop+: ON. Auto: OFF
Attack: 75 ms
Hld: 50 ms
Release: 75.0 dB/s
I made the adjustments you recommended and can't believe the difference!
You're the man!
Thanks so much.
viewtopic.php?f=60&t=1488
