High background noise
Hi, I wonder if anyone can help a newbie in setting up? I've read the forum from cover to cover but can't seem to find an answer to my problem.
To what I've read I've set things up ok, I've set the crossover, gain structure etc and I've flattened my speaker responses outside using the PEQ and already the system sounds x10 better but I've run into problems at gigs when trying to set up the auto EQ.
The volume adjustment works and gets the levels right between the 12"tops and the 18" subs but everytime we then try to run the auto EQ it tells us that the background noise is too high but now the subs hardly seem to be working! If I run the wizard programed for just the tops it works fine.
It's not the end of the world because I can manually EQ the room but a starting point would be handy before investing in smaart software to help.
Thoughts?
Thus, I did couple of tests and I concluded that if you set amplifiers volume at 100% (no matter what wizard suggests), the Auto EQ "noise" (during test) will be much louder (than normal condition) and the message “high background noise� won’t appear!
Of course, at the end of process, you ll have to set amplifiers volume back to wizard suggestions...
