Crossover setting - need help please
Hi guys I'm looking for a good crossover settings for my subs
The specs are below they are run in conjunction with hkaudio 15 plus horn top boxes
Thanks in advanced
Model PR:O 18 S
Title PREMIUM PR:O
Product Class Passive Systems
Info High-power-capacity 18
Power-handling nominal (RMS) 500 W
Power-handling, peak 1500 W
Power-handling, program 1000 W
Frequency response +/- 3 dB 48 Hz – 150 Hz (internal wedge)
Frequency response -10 dB 38 Hz – 150 Hz (internal wedge)
Nominal impedance 4 ohms
Sensitivity 1W 104 dB
Maximum SPL, @ 10% THD 129 dB
Connections 2x Speakon
LF Speaker 18"
Crossover frequency 150 Hz, 12 dB / oct.
Pole mount M20
Casters optional 100 mm
Handles 2, integrated
Enclosure MDF
Grille metal grille with acoustic foam
Finish acrylic painture, black
Dimensions (WxHxD) 53 cm x 61 cm x 64 cm
Weight 40,6 kg / 89.5 lbs.
Model PR:O 15
Title PREMIUM PR:O
Power-handling nominal (RMS) 300 W
Power-handling, peak 1200 W
Power-handling, program 600 W
Frequency response +/- 3 dB 60 Hz – 20 kHz
Frequency response -10 dB 53 Hz – 19 kHz
Nominal impedance 8 ohms
Maximum SPL, @ 10% THD 128 dB
LF Speaker 15"
HF Driver 1"
Horn characteristics 60° x 40° CD horn
HF protection (passive) Dyn. protective circuit
Crossover frequency 2 kHz,12 dB / oct.
Pole mount DuoTilt 3/7
Rigging points 3x M8
Dimensions (WxHxD) 47 cm x 61,5 cm x 41 cm
Weight 22,5 kg, 49.6 lbs.
  • I just had a reply from hk audio would like an opinion
    Hi Mark. OK, so our product manager says (well, he said it in German and we’ve translated, so hopefully this is understandable!):
    “Using a different controller than producer recommended will not equal the exact results the acoustical filters were built for. So we can only really give some ‘rough advice’ on how to handle the crossover here:
    With the PR:O 18, in order to not remove the passive crossover, with the Sub at 130Hz you can set a Butterworth 12dB/oct low-pass, and the top (at 130Hz) a Butterworth 24dB/oct high-pass.
    Now, if you have an all-pass filter, you can push the phase a bit to take care of that: although of course this is highly dependent on the building/room/venue you’re in.
    And in the bass at 100Hz you need to be narrowband in order to compensate for any ‘flabbiness’.�
    Hope that helps a bit! If it's not clear or the translation was not helpful, tell us and we can try again 😉
  • Still hoping for any other suggestions please
  • Sub:
    42hz BW24 (or 48hz BW18)- 100hz LR24
    Tops:
    100hz LR24
  • Hi thanks for the suggestion
    I find 100 to low
    I did try the settings hkaudio sent and found them to be better, with a lot smoother xover , all hk speakers are generally xover at 150
  • They would know their gears best.
