Home dbx Forum dbx Forum Archive DriveRack PA2
DRPA2 set-up advice to run 2 monitor mixes
edited October 2015 in DriveRack PA2
Hello Everyone,
I am setting up my DRPA2 to run 2 separate monitor-types (basically, powered guitar amps), each with its' own monitor mix on it. It is what we have and will be fine for our small, 4-person classical/accoustic ensemble... (The mains are on a separate DPRA2 and use 2 @ SRX812ps, no subs).
Monitor set-up:
1 @ Fishman LoudBox Artist amp/speaker = L monitor
1 @ Roland AC60 amp/speaker = R monitor
I am hoping to be able to Auto EQ each amp individually (and have PEQs for each amp). I am assuming that this means I need to have each amp/speaker on a different set of output pairs? So, Should I set-up a 4-way mono for full bandwidth, and set the left monitor to the L high output, and the right monitor to the R mid output on the DRPA2? If so, will the AEQ run 2 times: one for each section? Or, do I run-it for each section, individually?
I am assuming that the AFS is global, as well? This means 1 set of filters for all combined H-M-L output channel pairs out of the DRPA2 (not one AFS per output pair)?
I have read everything on this site for the past few days and am a bit overwhelmed. Just want to be sure I have understood this correctly.
Thank you for the help/info. I appreciate it.
~Shea
