Home dbx Forum dbx Forum Archive General Configuration Wizard
Cross Over Driverack PA+
edited October 2015 in Configuration Wizard
Hi , I have just purchased a Driverack PA+ , I have checked all videos out on Youtube , Read the Manual and checked out All Forum Topics , being an Old Schooler I would appreciate your advice on setting up the Crossover . I realise with the gear I have ( Will List Below ) that I need to select the custom config . Just not sure where to set crossover point for my setup . Here are my speakers and some hopefully relevant details ....
Subs x 2 Behringer 1800x Passive
40Hz-300Hz
Recommended Crossover = 175 Hz
Tops ( Hi's ) JBL SP215-9 15" + Horn 2447J
Freq Range ( -10dB ) 33HZ - 20 kHz
Freq Response (-3dB ) 42 Hz - 18 kHz
The JBL's are full range or Bi Amp , will be using for Mid High's .
Would it be best to to crossover the Sub at suggested or ??
Also with the JBL's I received a pairof tweeters JBL 2404H that can be mounted on the SP215-9 's . Would it be worthwhile or make enough diff to add these ??
Many Thanks in Advance for any help , I have done a lot of downloading and researching but ......
