PA+ setup with BFM subs
Hi so I;m trying to set my limiters to limit my drivers in my subs to 50v. However i am getting crazy high voltage readings out of my gx5 amps, like 80v. When I run the amps wide open to set the limiters I have to throttle the outputs on the DBX to where they are just barely registering. I need to know the output Voltage of the PA+. If it is +4dbu does that correlate to 1.2vrms? 1.2Vrms is the amp sensitivity for my amps. Im new to all this but just want to protect my drivers.
Also when sending the 60hz sine wave test tone thru the system without limiters set, the low output is registering higher than the input signal. Is this normal? Or is it getting boosted somewhere in the setup? The forum members at bfm tell me to not use the setup wizard because it does weird things to the gain structure. Is there a way to operate the pa+ and create a custom setting without using the wizard? Thx
