PA gain structure. Am I doing it right
Hi there....
I have a DBX Drivareack PA 2 and have a question about setting my gain structure.
I used to have only one amp and did at setup I was fine with, it worked and my amp was set to be at max. approx. -8 according to the PA setup…
Now I have bought another amp and used the setup procedure in the manual and on the video on youtube but I’m a little unsure if I’m doing it all correctly as now both my amps according to the setup procedure actually can go almost all the way up to 0db.
That is approx. -4db for the highs and like -2 to 0 for the lows
The procedure im doing is like this:
On my Midas m32 i go into oscillator and send pink noise directly to my main L+R channel
There is a trim/gain knob for the pink noise level and I set this to -16 (which as I understand should be Unity on a digital mixer)
I start off by setting my master L+R fader to 0 (Unity) and check that all compressor, Eq, Limiter and stuff is turned off in the Driverack. Then I raise my master fader on my Midas mixer until the Driverack Input just clips (which is my master fader at totally max +10db)
Here is my first uncertainty… Is it right to set the Pink noise signal level at -16 (thinking Unity) here? Og should it be louder?
Now with the Driverack input signal just clipping. The Driverack high output is just barely clipping, but the low output is something like only halfway up the meter? Is it normal that the low output have lower level. Or/And should I in the gain in the cross-over part adjust so they are approx. same level????
Well next I have disconnected my speakers and I now turn my amps up (2 x Dynacord SL 2400) until the just clip. And here it is I’m getting concerned because I can turn them pretty much up to -4 to 0db before they clip (like 95% way up)
Is that at good/bad thing? Does it just mean than my mixer to amp system are pretty much aligned from the start?
Well next thing offcourse is I go into limiter and set this up so my amps are just Not clipping anymore….
But the main concern is do I have to worry about my amps being able to go so high on my system
Did I do it right?
Ohh and by the way my amps are 2 x Dynacord SL 2400
Amps: 2 x Dynacord SL 2400
Mixer: Midas M32
Driverack set at +4db
Did I do it right?
Mixer: Midas M32
I also feel I did things right....
Propably the point where im most insecure is how high the pink noise signal should be for the procedure to be correct...
I will try do the procedure again in a cpl of days, maybe sending it to a matrix first....
My main concern also was sound quality (headroom) not protection... Since I have gear that exceeds my use anyway...
Im in a litlle trio rockband playing small to midsize venues and having the Midas M32 and 2x2400watt Dynacord amps I will problably never run into issues where The gear can't perform
Thx for your time answering :-)
If you do any permanent PEQ speaker tuning, that will affect the output relative to the mixer's meters.
