driverack pa/ life! /general questions
I worked most of my life as a DJ we never really had speaker management as such, just three amps, bass middle and top, and a general club manager who normally shouted to me 'turn the music down'. I booked carl cox once and spent the night with him in the DJ box- Is there a driverack pa that will help deal with the constant ringing in my ears from past times!!
ok so I have some martin audio aq8`s (three) and a turbosound impact180 sub, and driverack pa.
they say the eq frequency should be 66hz,on the aq8 but driverack does not give that option, should I go slightly above or below 66hz? if you have the binary settings, but cant quite match them, generally, should you go above or below?
the aq8`s info also give the low pass filter as being 22hz, but should i set the low pass filter to suite the sub, not the aq8?
Lows:
50hz BW18 - 130hz LR24
Highs:
130hz LR24 - out (all the way up)
The 66hz thing is immaterial for this set-up.
