How to configure these settings ?
Hello all,
I have bought AG Audio Pro PS-215 speakers, the manual says this :
- delay in : 6,167ms
- low : 90Hz 24db/oct type Linkwitz-Riley
- High : no
- para 1 : -5db on 3550Hz Q=1,78 (0,80oct)
- para 2 : +9db on 17890Hz Q=1,41 (1,00oct)
- limit attack : 8ms
- limit release : 16X (128ms)
On the speaker it says :
-3-way loudspeaker system 2x15"+3"
- Nominal impedance : 4 ohm
- AES : 1000W
- Max.cont.SPL : 131db/1m
- Nominal dispersion : 60° x 40° -6db
- Recommended HPF full range : 40Hz 24db/oct
- Recommended HPF with sub : 70-100HZ
I use them with Electro Voice MTL2 subs.
I've tried to set things up in the Driverack PA+, but i can't find all the settings. Like, i can't set para 2 on 17890Hz, do i select the closest value then ?
Can anyone point me in the right direction ?
Excuses for my bad English...
With kind regards
- High : no
- AES : 1000W
With kind regards
Any other questions?
With the PEQ settings, it says Q=1,78 (0,80oct), what and where is 0,80oct ?
What about the limiter settings, i can't see where i can set the attack to 8ms and release to 16x...
For the PEQ setting, press the EQ button until the PEQ screen is shown. Then press Next or Prev to get to the right page for the low output. The Freq, Q, and db gain areon the same page.
The limiters don't have that level of detail. Only threshold and knee type.
