Revisiting discussion on EQ wizard
First off, I tried to go to the archive, but the link sent me to the BSS audio site.
What I'm using other than the DRPA doesn't matter as much as how. I have a small set up in a church with a sanctuary that measures about 60'x50'. The set up I am using is an unlinked stereo config.. Using Left high, for mains, and Right mids for monitors. However, the group that was using them, no longer wants to, however, I still want to keep that config. in case we need the monitors.
So on to the question at hand. Mind you that this is in the "original" DRPA. Can I run AEQ on left channel, and then either exit AEQ, or go to save program to save the changes just on the left channel? The situation I've been finding is that for some reason, I'm having to re-EQ the room every so often after finding out that I'm having feedback problems. AFS seems to be working okay, but obviously it can only take you so far. Now, one other question. If you are starting the AEQ wizard on the same program, where does the EQ pick up? Is it from a predetermined point as per the programing, or does it start from the last EQ settings saved? Why do I ask? I began to have problems with feedback where I wasn't having any before. Everything the same, speaker locations, mics, performers, etc.. I was quite surprised at how much bottom end pink noise was coming through at the beginning of the AEQ. The difference in the room after doing the AEQ was definitely noticeable. BTW, the only two things that I can think of for the problems, are either it's been that way for a while probably because of bad EQ mic placement and I didn't notice it, or changes in the weather. :?:
Hope that helps.
