dbx 260 config for srx system
I run srx 728 subs under 725 tops. Qsc pl 380 amp for subs and qsc 5050 for tops. When I run wizard it says to set gain at -6db for 725. Should it be a negative? Wont that cause input to clip? Also, no setting for qsc all 380 amps. Any setting recommendations?
