Driverack 480 xlr inputs
Hello all,
Just a quick one, the xlr are pin 1 ground, pin 2 positive and pin 3 negative, right? Also, the 4 inputs have a pin 1 ground/lift switch. Can anyone explain this a bit? Thanks in advance.
Timtim.
Timtim.
PS - you posted in the PA section. There is a dedicated 480 series section.
Another quick one I need an answer on - The Driverack 480 has #2 pin as positive and the crest audio 9001 has #3 pin as possitive. Does this mean I have to make a cable with #2 pin from the driverack to #3 pin on the 9001 ???
Thanks in advance.
Timtim
Here is the link, if curious.
http://forums.prosoundweb.com/index.php ... 570.0.html
I'll bet anything the amp has a jumper to reverse polarity...some older Crests do
With regards to the jumper to change polarity, I don't think there's any. There's just a strip that says " signal ground lift ".
I was just wondering, why would Crest Audio make an amp with pin #3 positive when almost all other equipment have pin #2 positive??
Thanks again
Timtim.
Check out the octal sockets on the back of the amp
Timtim.
