RCF HD-12A over JBL Mpro 4118s
I'm new to your forum but the reading is great. Just got the new DRPA2. It is a bit more involved than my VSX-26 and is going into a new config for my bar band. We play a rock trio with a singer/harp player. Indoor mostly but a few outside gigs. I have 4 each of the HD-12A an 418s subs. We usually use 2 each in a club and all outdoors. QSC 3402 amp for the subs.
So the wizard wants me to set things a bit different from what I'm used to, like xover at 125hz, etc.
I will play my lazy card right up front and ask if I can get a more detailed perspective on proper settings.
Anyone have the prescription?
Thanks in advance,
dlbnh
Thanks in advance,
dlbnh
Play the selected sine tone through the system (once
again, the sine tone frequency should match the set crossover frequency of the drivers being tested) and invert the polarity on
one of the two drivers being tested – as previously mentioned, this test works best if the sound pressure levels of both drivers
are matched. Adjust the driver’s levels until the most phase cancellation is achieved. Try adjusting the driver alignment delay for
each driver to see if any further phase cancellation can be achieved – set it for the most phase cancellation. Note that most
applications won’t require any driver alignment delay. For more information on setting driver alignment delays, see ‘Delay’ on
page 39.
Once you’ve dialed in the driver alignment delay, perform this same “polarity� test while auditioning different combinations of
filter types in the PA2’s crossover to find the combination of settings which provide the most phase cancellation. When done,
make sure to switch the polarity back to the proper setting so the drivers will again be in phase.
