Home dbx Forum dbx Forum Archive DriveRack 200 Series 200 Series Software Control
Wireless control of DR260
How do you make use of bluetooth or serial to ethernet adapters to set up a network and control wirelessly a DR260? I already have a serial to usb cable which works fine, but I use a digital snake and would like control @ FOH, instead of on stage by the amp rack. I already have/use a wireless router for the console.
    If you're using a serial to ethernet adapter, try this:
    "DR260 serial connector" to "adapter serial connector". (Null Modem Cable)
    "Adapter ethernet connector" to "wireless router ethernet port" (NOT internet WAN port)
    Connect to router wirelessly with computer.
