Combine rooms in a Convention Center
I am about to start a Convention Center, i am going to use a 1260m, but i need to know how to combine 2 rooms, i need that once combined the romos the volume will be affected in both romos with the same control, is that posible, thanks a lot for the help.
There is a series of excellent videos on the set-up and use of the Zonepro and ZC's. Go here http://dbxpro.com/en-US/products/1260m
Then scroll down a bit and select the TRAINING MODULE tab.
