New dbx System Setup - Pointers Needed
Im putting together a new pa system together and be grateful for any suggestions and pointers on set up, eq, tunning specs. and so forth.
Here is my gear:
Presonus SL 16.4.2
dbx PA2 running tri amped
Peavey qw2 tops qw 218 bottoms
Peavey Irp2 5000 890 watts per side on each horns at 8ohms wich I know is to much but I already had the amp and will have to pad down.
Peavey Irp2 7500 1250 watts per side on each mids at 8ohms
2 ea Peavey CS4000's bridged @ 4000 watts 4ohms to each sub
Looking for any help as i always ran manual crossovers and have a pretty good ear but im new to the dbx world! I have a pretty good graps on the units and its utilities cause ive run tone of out board gear but wouls appreciate anny advise or set up pointers, thanks!
Here is my gear:
Presonus SL 16.4.2
Sub 45hz BW18 - 100hz LR24
Mid 100hz LR24 - ??hz LR24
Horn ??hz LR24 - out
One stack, outside, mic about 15' in front.
Crossover frequency (internal passive):
Low frequency - high frequency: Mids to Highs
52 to 1,200 Hz L/R 24 I wouldnt cross it that low, I use 75 Hz
1,200 Hz to 18 Khz L/R 24
Time offset:
Low frequency: delay 0.27 ms
High frequency: 0.00 ms
frequency response from 52 Hz to
18 kHz.
These are the Internal QW Crossover points, and they use the LR 24 dB Filters....
Make sure you connect your speaker cables to the FULL RANGE input on the QW2 for this method...the internal crossovers on the QW2 are very robust and will take a pounding, its a simpler method and saves some headaches and Amps for other needs..
You then setup your DRPA 2 in the Stereo wtih subs mode, Use the NOT LISTED speaker option which will give you a neary perfect xover and setup is done...
