Please Help setup my K12
edited June 2014 in DriveRack PX
Tops:
K12 1000 W Class D
Freq response (-6 dB) 52 Hz - 18 kHz
Freq Range (-10 dB) 48 Hz - 20 kHz
Maximum SPL (1 meter) 131 dB peak
Transducers
LF 12" cone transducer
HF 1.75" diaphragm compression driver
Thanks a Bunch!!!
  • A little late in the reply, but the DRPX has the K12 setup built into its programming. Enter the setup mode and scroll through the speaker choices until you get to QSC K12, then select it. Also choose whether you will be using subwoofers with it or not, and if it will be 2 subs (Stereo) or One (Mono). The DRPX will guide you through the rest.
