Driverack PA+ AFS Question
Hello,
When I use the AFS function on the DRPA+ (two open mics with monitors), is it possible to use a couple of Fixed filters on Speech to catch the biggest feedback 'offenders', and then change it to Music Low for a couple, then change up to Music High for a couple? That way I know that the frequencies with the worst feedback frequencies will be caught first. I just don't know if it is possible to change from Speech to Low to High settings in the middle of doing this? Thanks for your help.
May I ask one more question please. It is always just me sitting at the piano with a mic, and a singer who stands a few feet away or sits on a stool nearby. We hardly move (piano bar sort of style and songs). What is puzzling me is the AFS Live Filter Lift. I have always set the AFS so that once the feedback is caught then it is not lifted. Surely if there is feedback and the filter is lifted after a few seconds, then that feedback frequency would occur again? Could you explain more about the Lift facility please and let me know what I should be doing please as this is confusing. Thank you again - I LOVE this site and appreciate your help.
The Lift is for changing environments (mic technique, orientation / axis / elevation of mic to speaker / monitor, even room temp and humidity).
If you believe that a recurring frequency is returning after a lift and release, then you should increase the number fixed filters by one or two and get rid of it once and for all.
Thank you again.
