Driverack PX sound dropping
I setup my Driverack PX a couple different ways. Using a pre-existing setup with just 2 tops and then running with the wizard. So far I just have it in my basement testing and on several occasions after playing fine for a short amount of time the sound starts crackling and eventually dropping out and then re-appearing regardless if the level coming thru it is low or high. I've turned it off, back on and it kinda continues that pattern. I have bypassed the DriveRack to make sure it isn't something else and it works fine. The cabling should be fine. Is there anything that would cause the unit to start compressing even though the volume isn't really doing anything abnormal. Could I just have a bad unit? Any help or suggestion appreciated.
