can't hear kick drum and can't hear vocal
Myconfig is:
2 ev elx 115p tops -- self powered
2 ev elx 118p subs -- self powered
mackie pro fx22
driverack pa+
Room size is 35' x 35'
I'm using a yamaha sub kick and a audix d6 mic on the kick.
I placed one sub in a corner and the other sub against the opposite wall.
The tops are placed on the floor aimed up at the guitarists/vocalists.
I experimented with balancing( the output of the subs and the tops is @ 55 - 60 % as directed by the drpa) and with the auto eq ( experimented with ALL notches )but I cannot get the sound that I want. When I pink the room, I turn up the pink noise until it says turn down -- usually get the message around -5 db.
Without auto balancing, the bass over powers the music -- either recorded or live. With auto balancing, the drpa cuts the bottom by -10 db or more and emphasizes the mid range.
Also, the vocals are barely audible from anywhere in the room except directly in front of the tops which are on the floor.
I know this can work.
Please help!
mackie pro fx22
driverack pa+
Please help!
