Physical Placement Of DRPA+ and DR260
Hello,
I now have one each DRPA+ and a DR260. The DRPA+ will be used on 4 monitors powered by two amps in a 12U rack. The DR260 will be used on the FOH consisting of two 15" tops and two 18" subs powered by two amps in another 12U rack. All is going through a 16 channel mixer out to a 100' snake. Mixer is outfront and racks are side stage, 1 left and 1 right. Running Mono.
Recognizing I can place the units anywhere, I'm requesting input on the most logical position to locate the DR units.........DRPA+ in monitor rack and DR260 with laptop in FOH rack or both DR units with the mixer?
Don't have a dedicated sound man.
Thank You for the input.
Thanks, again, DRA!! And yes I'm using the GUI on the 260.
