Driverack PX 'Q' Mode
Hi,
I'm utilizing the Driverack for a duet. We use custom built performance tracks along with live instruments. I'm not sure which "type" of Q I should be using...ie, whether to use the setting for speech, music low or music high etc.
Would someone give me some guidance?
Thanks.
Thanks.
If not, go for the Music high. The good thing is that even if you end up using speech, it is a tighter filter than a 31 band EQ.
Simple answer... use the highest setting that gives you the results you want.
That is the perfect information I was looking for! I've been using the Music High selection and have very, very few feedback issues. So, I've been doing things right! or least right for our setup
Is it possible that I could eliminate all feedback issues by using a higher number of LIVE filters and fewer fixed filters?
Another trick... after you set your fixed filters, switch to live and change the Q to speech. Speech works much more quickly to grab feedback.
To access the AFS parameters press and release the AFS button (holding it down will access the wizard). Read Section 3.7 on page 18 of your owners manual to learn how to navigate and make edits.
