Do I Need My DRPA+?
Hello All,
I presently own 2 x XTI 4002 Crown Amps, 1 x XTI 6002 Crown Amp, 2 x MRX 512 JBL Monitors, 2 x MRX 518S JBL Subs, and 2 x MRX 515 JBL FOH Speakers.
I've had a DRPA+ for a year now and haven't incorporated it into the mix yet.
As the subject reads, do I really need the DRPA+ in the mix due to the DSP functions in the Amps? What could it bring to the "party" that I don't already have?
Your input is greatly appreciated.
Regards,
Bucksarge
  • Right off the bat... AFS, GEQ adjustments, Auto EQ (if you would ever use it), and x-over gain changes.
  • ... at the mix position, I should have added.
    Wow! That was a quick response.......thank you very much.
    I'm running a Mackie 1604VLZ3.
    Would you please clarify for my feeble brain your statement above :D
    Regards,
    Bucksarge
  • If you don't use the DRPA+ and need to make a system change (response of the speakers), you have to go to the amp rack (and probable get down on your knees).
    Ahh, I think I understand. You're suggesting the DRPA+ at the mixer instead of in the rack (where it's presently located). Very sensible and yes, I'd have to get down on all fours to adjust.
    Thanks again, I appreciate the responses. I'll most likely be back with questions when I set up the DRPA+.
    Regards,
    Bucksarge
