Questions about "indoor EQ"
Okay, so I get the idea behind this new method of EQ. It's basically to use the concept of a pressure zone mic. Now, wouldn't that just affect the characteristics of the speaker rather than the room as well, or is that the point? I've perused several threads on EQ and one or more of them talk about just laying the mic on a table or the floor, but aimed at the speaker. Would this apply if the speakers are up on stands so that they are ~ 6 - 7' in the air? Can I rig something so that I can put some sort of flat plate (wood) with the EQ mic up to the speakers, and if so, how large a piece do I need?. I know that putting the speaker on the floor and aimed properly is probably the best option, but the group is using powered speakers, and I can't get them down by myself. Well, I can probably get them down but not back up.
In all cases the reflected energy (walls, ceiling, floor) is something that the Driverack does not interpret well at all frequencies (particularly below 170 and above 700).
In a room correction, the mic on the floor (or wall or ceiling, the floor is just easier) makes the nearest reflection super fast so it doesn't interfere with the performance of the AutoEQ module.
Hope that clears up your confusion.
In the room to be "EQ'ed" power up one stack only. This helps the process greatly. Place the mic on the floor, on a towel if available, pointing toward the speaker. The mic needs to be in the pattern of the horn, so you may have to be 15 - 30 ft away, depending on elevation and tilt (if any). Personally I like to be about 1/3 to 1/2 of the depth of the audience space.
I would like to ask another question here not about DRPA, but about aiming the speakers. Here's my problem. The speakers are at the side of the room essentially in the corners. The option is to move them toward center on either side of the projector screens, but I don't know if the other church group using the system will go for that. The issue is basically this, the more I turn the speakers toward center to avoid sound bouncing off the walls, the more overlap I get in speaker coverage in the center which of course gets worse the farther back I go. The main part of the room is roughly 50' wide by 60' deep. The advice given to "just aim the speakers at the audience" doesn't help a lot. This of course comes from what I've read about the evils of having the sound bouncing off the walls and the problems with the low end resonance which is one of our problems, or overlapping toward the center which invites combing effects which are not desired either. Is the best to experiment with this or is there a specific guideline? I should note that this may be the only option for speaker location as I don't think, as I said, they will go with moving them in towards center, and flying the speakers is definitely out of the question.
Without going to a center cluster you are going to have to compromise the results. I would rather have comb filtering with the speaker aimed on the audience than have incomplete coverage.
1. Lay speaker on it's side.
2. Put mic ON the floor with the mic (on a towel) tip facing the speaker or should it be facing the floor straight down off a stand?
There are a few discussions on this and I am not sure which works out better. 6ft far enough?
3. Should the mic be between the woofer and horn or right at the horn if the mic tip is suppose to face it?
4. I set the volume how loud being that close and indoors? Loud enough to take the reading and hopefully avoid too much reflection back?
5. Should I just do my tops only with this method and then simply adjust / EQ on my subs on the fly?
If I did decide to outdoor is this correct:
1. Place mic on stand facing speakers roughly half way between sub and tops?
2. How far from trees or other should I be behind the mic so as to not get reflection that that mic will notice?
3. Volumes should be at normal playing / concert levels?
Sorry if these are repetitive questions, but I needed to ask them my way so I can understand it.
It would be great if someone made a video showing this. I am a much more hands on / show me how it's done person.
Lastly - Are the presets good from DBX for the speakers they have done or should I just Auto EQ and get the flat response myself?
I'm trying to understand this all before I try it. My DBX PA+ is on it's way as I type this.
I also have the DBX mic - Is there a better one - I would spend up to $400 if it really made THAT much of a difference.
Again ... sorry for any redundancy, I just really want to get this done correctly as I totally understand working with a flat system is MUCH easier to work with and makes EQing a room easier.
Thanks for any and all help -
Brad
I really appreciate the reply.
I did find that post, but it wasn't clear enough to me for the indoor method thus the questions.
I do have Smarrt on my Presonus. Is there a mic you recommend by chance?
I think once the PA+ comes in I will just do the outdoor method. Or maybe just try both just to see what the two different settings sound like.
Thanks again!
