Recomendations
I got
SP2 NEW MODEL X2
SP218 NEW MODEL X2
DRPA+
CROWN XTI 4000 X2
QSC PLX 3602 X1
QSC GX5 X1
PRESONUS 16.4.2
ANY RECOMENDATIONS FOR POWERFULL CONFIGURATION WITHOUT DAMMAGE...
THANKS
SP2 NEW MODEL X2
SP218 NEW MODEL X2
DRPA+
CROWN XTI 4000 X2
QSC PLX 3602 X1
QSC GX5 X1
PRESONUS 16.4.2
THANKS
SP2: 500 / 1000 / 2000 (8 ohm)
SP218: 1200 / 2400 / 4800 (4 ohm)
For live sound: (assumed from the Presonus)
If you want your speakers to coast and last forever.... Go with Continuous power. (also good for the amp)
If you want your speakers to work and last a long time... Go with Program power and never clip.
If you want to push them to their limit... Go with Peak power and don't get within 6db of clipping. (hard on amp)
Safe:
SP2 @ 500w (8 ohm):
Xti (650w) -or-
PLX (775w) -or-
GX5 (500w)
Safe:
SP218 @ 1200 (4 ohm):
Xti (1200w) -or
PLX (1250w)
Safe:
SP2 @ 500w (8 ohm):
GX5 (500w)
Considerable risk (depending on music type and input level):
SP218 @ 2400w / 4800w (4 ohm):
XTi bridged (3200w) -and-
PLX bridged (3600w)
Safe:
SP2 @ 500w (8 ohm):
Xti (650w) -or-
PLX (775w) -or-
GX5 (500w)
Safe to some risk: (note: Some will run their sub amps into clipping (not full time clipping, just peaks). It "dirties" the sound, making it sound louder. Roughly doubling the available wattage. The good news here is that the clipped power is right at or just above the continuous rating.)
SP218 @ 1200 / 2400w (4 ohm):
Xti (1200w - 2400w clipped) -or
PLX (1250w - 2500w clipped)
you had any recommended setup or parameters in the drpa+ for me?
Subs: According to Peavey they only go to 51hz (-3db), so...
50hz BW18 - 100hz LR24
Tops: 100hz LR
