RTA and pink noise at same time without Auto EQ?
Is it possible for the PA+ to output pink noise and display the RTA at the same time without running Auto EQ?
  • No, but why would you want to? You could get some pre recorded pink noise and send it through the mixer and out...Are you looking to manually Eq the room?
  • Yes. I would like to use my PA+ to help manually EQ someone's church system (using the RTA and PNG). I have another portable PNG, so I will use that. Just thought maybe I wouldn't need it. They should just buy a DriveRack, but they can't afford one right now. I am just trying to help a friend's church out.
  • Why not just insert the DRPA into their signal chain right after the mixer and before the EQ and x-over? Duplicate the DRPA's GEQ on theirs, rinse and repeat until the DRPA doesn't make any (many) changes.
