Channel display issue?
Hi all,
Just setup my first PA+, really like it so far although the settings for my system sounded way too boomy using the defaults for the equipment, but a few manual tweaks to the crossover settings and all is good.
I seem to have a problem with the gain display though, as this is the first one I have used I wanted to ask here before I talk to tech support. The input gain meters seem to be working properly; on the output section though, only the light at the bottom works and then periodically (like it should) I get a slight flicker to red on the TH. This happens on both the low and high channels (running 2 way), it almost seems like all the LEDs in between are burnt out.
I have no issue with gain, I am driving the system cleanly to high output levels and the slight red flicker at TH is where I would expect it to be. Has anyone come across this? Am I right in assuming this is just a normal progressive gain meter and I should be seeing it climb through all segments before getting to TH?
Just wanted to make sure there wasn't a simple fix before I talk to tech.
Rob
Rob
I will look again at the settings as I know for sure compression is off and pretty sure I set limiting off as well but maybe it is on. Weird they don't explain this very well in either the manual or the quick start guide.
