260 Connectivity Problem
I'm a newbie to this forum. I'm trying to update a DR260 with the 2.6.2.0 firmware, but am having trouble establishing a connection between my laptop w/ Vista and my 260. I have the null modem adapter, a USB to RS-232 adapter with the dbx recommended FTDI chipset. The Driveware is loaded and I have v 1.600 on the 260. Is this the most current update available??
I have 4 USB ports on the laptop, 2 on each side and 1 is the mouse. I am plugged into the lower left port on the laptop from the 260.
As soon as I open the Driveware or try to 'Connect to the network' I receive a message that says "an error occurred while opening Com port 1. Please check the port and try again." I have tried changing the com port on the Driveware to port 2,4,5,6,7, etc., all with the same results. The only difference is when the Driveware is set to port 3, it says "Network not detected. Working in offline mode."
I assume that port3 is the correct port, but why won't it connect?
Im not familiar with vista...I hope XP info is of some help.
Plug in USB-RS232 adapter to desired USB port.
Click -Control Panel-System-Hardware-Device manager. Now click + sign beside Ports (COM & LPT). At this point, check which COM Port your adapter is using.
Open Driveware. Click -FILE-PREFERENCES. Click on the PORT drop down menu and select the same COM number that showed up in
Device Manager. Did that help?
If nothing above fixes the problem it's possible your serial adapter has a driver issue
Just read your last post. Port_#0001 isn't offered as a location in driveware. Your options are COM1 to COM16
+Modems
+Monitors
+Network Adapters
+Ports (COM and LPT)
+Processors
+blah
+blah Then
+Universal Serial Bus Controllers with
(7) Intel Host Controllers
(2) USB Composite Devices
(7) USB Root Hubs
and at the bottom of the list is my USB Serial Converter <--This is where I get the goofy #port 0001 number.
But if I pull the USB cord, the Ports (COM & LPT) listing disappears along with the USB Serial Converter.
What exactly is listed when the USB cable is connected?
Yes, he walked away in the middle of a conversation! We might have been onto something since Driveware hates sharing COM ports with anything and all of his USB ports were on COM 10
