Problem with mic placement for Auto EQ
Hi -
Just got a DRPA+ last week and so am new to the forum. I've seen the posts regarding mic placement for the Auto EQ process, which poses a problem for me.
We are a church band playing in a small gothic-cathedral-style church playing contemporary music. (so the reverb is atrocious!) Anyways, placing the RTA mic on the floor 25 ft. directly in front of one of the speakers will place it under the church pews. I assume this is bad. Placing in front of the church pews would put the mic about 12-15 ft. in front of the speakers.
I would appreciate suggestions.
Thank you!
Mike
Thank you!
Mike
Select the correct mic position and lay a sheet of plywood across the top of the pews at that point. Set the mic on the plywood. The capsule end of the mic should almost touch the plywood
Also, if the reverb is that bad, aim the speakers at the people (and keep it off the hard surfaces) and keep the volume as low as possible! these are the only ways (including getting the frequency response as flat as possible to not excite the room further) to deal with these problems...
The table / plywood idea is a good one.
Do I point the mic at the plywood? (I saw this in a picture here somewhere) Or do I set it on a towel and point it at the speaker?
Mike
