DriveRack and external Eq
I am currently running my PA with a DBX Drive Rack Px for powered monitors. I am not happy with the Eq built into the DriveRack. I have a 31 band 2 channel Eq can I run it through the Drive Rack with out creating any problems? If so do I run the Eq into the DriveRack and out to the Pa or the other way around? Please feel free to send any input. Thanks
I'll assume that you don't like the difficult manor for adjusting the GEQ. (press, turn, scroll, press, turn, scroll) That is true, an old grab-a-fader-with-your-finger EQ is much easier to use on the fly. Play, play, play. It will get easier. If you insist on adding the piggyback EQ, put it after.
1) Set the add-on as you see fit.
2) Copy the graph to the DRPX
3) Flatten the add-on
4) Use the add-on for "quick repairs" as needed.
You may see that after a few set-ups that you won't need to adjust the add-on. If this is the case, you may opt to remove it from the change.
Bobo,
Auto EQ CAN and many times WILL mess up your sound, if you use it the way the manual describes. Go to the Start Here section and read up about the auto EQ. Also do searches for auto eq. It has been discussed and clarified ad nauseum.
I am extremely happy with my PX but it takes a bit of getting used to and then some fine tuning. The manual leaves a bit to be desired and I gained more by the gift of time and knowledge given here.
When I got the PX it freed up my FOH EQ to use on my monitors. I use the left channel for the floor monitors at the fornt of the stage and the right channel for the drum fill. It works really well and is quick to set up as you can set the Monitor EQ for each feed from the desk feeds independantly. My Whole PA system has powered speakers for the FOH and Monitors.
I dont have a dbx PA drive rack but undertsand that may do what you are wanting.
I can't find the "Like" button.
We are so addicted to Facebook!!!!
walwarts = love hate
face farts = finding out what my kids are up to today... :roll:and little else...
