Home dbx Forum dbx Forum Archive DriverRack PA & DriveRack PA+ PA Front Panel
Rane RTA mic
edited January 2013 in PA Front Panel
Recommended for DRPA+? will results be different in any significant way?
Thank you,
a dude in Sutton, MA
    Thank you,
    The Rane RTA mic is an odd duck with a 1/4" connector and runs on a DC voltage...check out link. RaneNote 104 is obsolete and no longer on the Rane website. For a better view, save it to your computer.
    http://www.findthatdoc.com/search-11205 ... 04-pdf.htm
    You might make it work but you will need to do mods
  • Sorry re: not giving enough detail. How about this scenario?
    RTA30 with MIC2:
    Microphone Type Back-Electret Condenser 6 mm capsule
    Frequency Response 20 to 16,000 1 dB +2 dB at 20 kHz
    Polar Pattern Omnidirectional
    Impedance 1.8k 5% Ω With 2.2 kΩ load
    Sensitivity -44 ±3 dB re 0 dB=1V/Pa, 1 kHz
    (6.3 mV @ 94 dB SPL) 1 Pa = 94 dB SPL
    Maximum SPL 140 dB 1 kHz
    Signal-to-Noise Ratio 58 (re 94 dB SPL) min dB 1 kHz, A-weighted
    Phasing Non-inverting Positive diaphragm pressure equals positive output voltage
    Power: Voltage Range 1.5 to 6 VDC T-power; absolute min and max ratings
    ..........Rated Voltage 2.0 10% VDC
    ..........Sensitivity Loss -3 dB @ 1.5 VDC
    ..........Current Demand 1 max mA @ 2.0 VDC
    Cable 25 feet (7.6 meters) 2 conductor shielded; XLR-F to -M standard mic patch
    Case 6" x 9" (15.2 cm x 22.9 cm) Zippered heavy black vinyl
    Storage Temperature -20 to 60 ºC -4 to 140 ºF
    Operating Temperature -18 to 50 ºC 0 to 122 ºF
    Relative Humidity 0 to 95 % Operating or storage
  • Note 104 was about MIC1 but you appear to be asking about MIC2. It sounds like the mic cable has been changed but MIC2 still requires 2VDC while the current standard for condenser mics is 48V phantom power. my understanding is, you can use MIC1 or MIC2 but it requires mods and I believe they are explained in RaneNote 104.
  • Excellent. Thank you. I appreciate your rapid responses.
    ac
