Target Curve Details, AUTO-EQ section
There are a couple different Target Curve Options when running Auto-Eq.
Can someone advise the +/- @ Hz assumptions used in the Rock Preset?
I notice it has a "bass bump" with a dip as it moves up the frequencies, and am curious what settings were assumed as "correct" for Rock.
I don't like a totally flat system most of the time, but in difficult rooms, where any excess energy causes problems, flat is best, you'll get the best gain/intelligibility quotient.
In more "normal" spaces and outdoors I ten to mix with a system that is low end heavy (has a bump in the LF region) and generally falt midrange and gently sloping response after about 5-7 khz (mostly for listening fatigue reasons).
You can easily set up presets for the different "pre-curves" and audition them and see if any of them are to your liking.
