gain structure using a pioneer ddj s1 into driverack 480
hello all,
I need some help with my system. Firstly, I want a do a gain structure ( i followed the guideline in forum, it worked well when i was using my cdn95, but now i'm having some problems since using my pioneer ddj s1). Secondly, i want some advice on crossover & eq settings. i am presently using a 2 x 4 crossover.
Here's my system -
DDJ S1 > DRIVERACK 480 (inputs 1 & 2). OUTPUT 1 > CHANNEL 1, MARATHON MA-3050 AMP FOR HIGHS.
OUTPUT 3 > CHANNEL 2, MARATHON MA - 3050 FOR MID HIGHS.
OUTPUT 4 > CHANNEL 1, MARATHON MA - 5050 FOR MID HIGHS.
OUTPUT 5 > CHANNEL 2, MARATHON MA - 5050 FOR LO MIDS.
OUTPUT 7 & 8 > 2 CREST CA18 IN PARALLEL MODE FOR SUBS.
MY SPEAKER SYSTEM
4 EAW KF850 FOR TOPS - EACH BOX CONTAINS 1 AUDIO PIPE, ATX - 6650 TWEETER FOR HIGHS; 1 HORN WITH SELENIUM D405TI DRIVER, FOR MID HIGHS; 1 EMINENCE, DELTA - 10A, ALSO FOR MID HIGHS; AND 1 JBL 2225 15" FOR LOW MIDS.
4 SELENIUM SUBGRAVES HB1805C1 SUBS.
I have tried different crossover & eq settings, but my system still seems lacking. I use my system both indoors and outdoors.
Thanks in advance for any help offered .
Timtim.
Here's my system -
MY SPEAKER SYSTEM
Timtim.
I cannot get to read the "views" from my post. I'm seeing 45 views and 1 reply. I read the reply but can't get to the "views".
Timtim.
Thanks the reply.
The compenents are not the originals. I bought the EAW 850 boxes empty.
I also installed a tweeter in each to enchance the highs. I'm using it as a
3 way, with both the horn and the 10" for the mid highs from the drive
rack. Am i doing something wrong here (with horn & 10" for the same frequency range)
The views are just that, people viewing the thread... in the biz we call em 'lurkers' here to learn and see what s posted...
Well, what were those speakers you put into the EAW's, you do realize that you cannot just put any old speaker into a cabinet and get the original performance, or anything remotely close don't you? In LF cabs (especially) the chamber the speaker is in is a special size so that it damps the excrusion of the woofer...preventing it from running up against the mechanical stops, and tearing itself apart...
The added driver is also an odd addition, the original speakers had 18K frequency response...
Timtim.
AUDIO PIPE, ATX - 6650 TWEETER FOR HIGHS - I INSTALLED THIS ABOVE THE HORN
1 HORN (THIS FLARE IS THE ORIGINAL THAT CAME WITH THE BOX) WITH SELENIUM D405TI COMPRESSION DRIVER, FOR MID HIGHS
1 EMINENCE 10" SPEAKER , DELTA - 10A, ALSO FOR MID HIGHS
AND 1 JBL 2225 15" SPEAKER FOR LOW MIDS.
ANY FURTHER THAT YOU MAY REQUIRE PLEASE LET ME KNOW. THANKS AGAIN.
TIMTIM.
Timtim.
