Speakon Cable Bridge Mode
edited October 2012 in General Discussion
When you are rewiring a speakon cable +1/+2 to support bridged Mode, which wire the black or white is supposed to be on +1?? Does it matter?? I am running 2 Subs from one EP2500 Bridged Amp so I will be daisy chaining my 2nd sub from the 1st with a normal 1/4" Speaker cable. I am getting a thought that if the wires aren't exact on sub will push while the other pulls if wired wrong... am I correct in this thinking??
  • Nevermind, found it in a video by Ampeg, Tip=+1 and Sleeve = +2.
  • Correct. As long as the color remain constant, it doesn't matter. White = Hot is standard, though.
    Except speaker wiring.
    http://whirlwindusa.com/media/uploads/d ... orcode.pdf
  • That goes against what I've alway read and seen. The reason is that some cabling matches the coding of the terminals on the driver (Red = "+", Black = "-"). To remove confusion, black is always "-" regardless of the other conductor's color. My main source is Yamaha's "big book".
    I find it odd that Whirlwind (and maybe more) changed the codes for NL's while "all other 2 conductor" speaker cables (1/4 - 1/4, Banana - 1/4) remain White = "+", Black = "-". There must be a reason, but I don't see it.
    A lot of folks do not consider 1/4" and Banana to be "pro" audio
  • 2shay :mrgreen:
    But, virtually all speaker builders use Speakons on even their crap lines. Some would say that those lines are farrrrrrrrr from pro grade. :wink:
    I only argue the reasoning behind a different color codes based on product classification.
  • Dra wrote:
    2shay :mrgreen:
    The crap line of speakers still use the exact same Speakon connectors as you would find on a national touring system and that color code is the same. If you need reasoning, they have adopted an Alternating Current color code standard instead of a Direct Current color code standard
  • Inside speakers I have seen MANY colors, and no discernible "standard"... The only way to be sure is check the crossover or actual drivers...
