Mixwizard 16:2
Hey Dra,
Does your Mixwizard 16:2 have the option of being able to meter just the Master Channel??
No, that I can see. If you are mixing mono (summing the L&R and using the main out only), you could just pan everything Left (or Right) and use the Left (or Right) output to be able to use the meter.
