What does the PX store
When you set up your PA in a venue and use the Set Up, Eq and AFS wizards and then save the results, does it actually save all of these settings for recalling in the same venue next time you are there. Or does it only save the set up, so you then need to re-run the Auto EQ and AFS wizards again?
I suspect only the latter but am just wondering and needing clarification.
and yes it will store the AFS results (the FIXED frequencies) but this could change from time to time, and will with varying audience size... I dare say if your system is tuned properly you won't even NEED the AFS for the most part...
Anything you do will be stored when you press the store button. If you do it right, you will be able to go back to that room and recall your setup and be ready for business.
We have complied all the information you need to set up your system PROPERLY in the 'start here' thread :
viewtopic.php?f=61&t=959
And the FAQ section:
viewforum.php?f=60
Where you will find the secrets of unlocking the driverack and getting the most out of it's toolset. GO by the manual and fail miserably, or empower yourself with the knowledge we have amassed over the years...what REALLY works...
Not trying to be flip here, but to tell you what you need to learn to make your life easier and get the most out of the driverack...
