driverack settings
edited August 2012 in General Discussion
I have 2 Behringer B1500D Pro Eurolive Powered Subwoofer and 2 samson auro d15,what should my driverack settings be,i have a driverack pa
  • So, 2 pairs of dissimilar 90 X 40 coverage speakers, why not tell us what you intend to do with them?
    Before you vault forward, let us indicate that covering the same area with 2 or more HF deices in a given area... causes all manor of sonic anomalies...
  • Gadget, Are you referencing another posting? Where did the "2nd pair of dissimmilar 90 x 40 speakers" come from? :?
  • eyes still aren't workin right... never mind...
  • Set the filter knob on the sub to 150hz (max high).
    Set the subs (low) range in the DRPA to:
    45hz BW18 - 100hz LR24
    Play with the boost freq (don't boost above the x-over frquency)
    Set high range to:
    100hz LR24
    That should work for you.
    You can also try a higher x-over, say 120hz or lower, say 90hz, but go with what sounds best. (likely 100hz)
