recommendation for dj settings
Just like alot of others; I am very new in setting up my pa properly. I have a qsc gx7, a drpa+,2 pv pr10 for tops an 2 pv 118 for subs. I would very much like some recommendation for settings on my drpa+. Could you help me out? Thanks
  • Why did you start a second thread? I already started answering on the other one...
  • Im sorry. But my first post I wanted to make sure that I connected everything correctly. Now I wanted to get some recommeded settings to get the best sound I can get with what equipment that I am using. Thanks for your quick reply and help
  • All parts of the same setup... just wanted to see if there were any questions about the setup thus far...
    The rest:
    As before in the wizard set up a stereo tops stereo subs all custom speakers and amps...
    Load the setup
    press the xover button, set the subs HPF (the L out) @55hz BW18
    set the Subs HPF @ 150hz LR24 (or as close as you can get)
    move to the High outs (H) set the HPF @ 150hz LR24
    Do the auto eq... you'll need to read about Auto EQ in the FAQ section and gain structure in the "start Here" thread
