New to the PA+, question about an odd setup
Hi all,
I just got a PA+ on recommendation over the PX (even though I typically use powered tops / subs). I was hoping that there would be more speakers available (or the ability for us to somehow create our own profiles to upload), but I can deal with that.
What I need help with is an unusual setup for an event this weekend. I'm in a rather large room and my front speakers will consist of a pair of QSC HPR-152f and an HPR-151i sub. The rear "fill" will be further than I have for delay on the PA+ (not a big deal), consisting of a pair of QSC K10's.
How should I configure my system to run full-range signal to the front and rear, and low-range only to the sub?
I would usually run the wizard when using my K10's and the sub (using the 181i settings), but I'm guessing for this setup, I'd have to manually set things? Any help of tips would be appreciated!
viewtopic.php?f=27&t=3137&hilit=mains+and+monitors
This way if you want to auto Eq you can do it once and be done... just follow all, the other rules for auto eq..
You can set up presets for other speakers, like the K10's... if REALLY look at the setups there isn't much more than a HPF in them anyway, unless there is bi-amp setup... THEN you'll see some different things in the crossover, Eq's and delay.
