Home dbx Forum dbx Forum Archive DriverRack PA & DriveRack PA+ PA Connectivity
DRPX settings on QSC K10 and AFS settings
edited June 2012 in PA Connectivity
Hi! Grateful if you could assist me on settingup my drpx on its custom speakers setting .
I know that the px could squeeze every juice out of my system but will leave some for the headroom when required.
As I do alot of Live Event as an FOH (Acoustic Bands and DJ gigs), Im kind of confuse on the AFS settings, the Fixed and Live. Shall I put 6 Fs and 6Ls on the AFS settings. Your kind help will be greatly appreciated.
My simple setup:
Hi/Mid Freq - Stereo:
2xFull Range: QSC K10
Frequency Response (-6 dB) 60 Hz - 18 kHz
Frequency Range (-10 dB) 56 Hz - 20 kHz
Low Freq Mono:
2xSubs: HK Audio Powerworks RS Sub15a
Freq. range: 50 - 130 Hz
it's got a built in crossover that rolls off at 24db/octave on 130 hz
Bigdaddi
DJ/FOH soundguy
  • Try 6 & 6 and see it you get the volume you need. If not, increase the fix #. Also try different settings: speech, music low, etc. Start with music high first. That is the least damaging, but may not provide the needed correction. Trial & error my friend.
    Thanks DRA! Appreciate your advice and ill do just that.
    Grateful for your kind advise on my query on the custom speaker setup
