Gain Structure: Does this sound correct?
Followed the gain structure instructions. Since it is a little different for the DriveRackPX, can you please confirm I am good:
1) Played the pink noise generator that was suggested. The volume of the player (on my computer, connected to my mixer via a Motu Ultralite interface) was at 100%. The instructions did not indicate the level of the source really mattered though.
2) Enabled the PFL on the channel and turned up the gain as instructed. On my Allen & Heath MixWizard 3 16:2, I turned it up to just below clipping (+9)...clipping red light is +16.
3) I deactivated the PFL. As far as I can tell, my mixer has no AFL switch. With the master fader at 0, the meter was at +6. I turned up to just barely getting a clip, master fader was at about +5.
4) Looked at the DriveRackPX. Here is where the instructions on this site are confusing:
"if the meters on the mixer are at just clipping and your using +4 and the meters on the Driverack are anywhere above the 0vu but below the clip light your fine... there is no input mixer to adjust... If the signal is low try the -10 setting and see if that gets you to a more appropriate setting."
OK, my mixer meter was just clipping. But on the DriverackPX, 0 IS clipping. The input meter says "Headroom dB" and runs O=red/clip, 6=yellow, 12-36=green. There is no "above the 0vu but below the clip light". Is "Headroom dB" something different than 0vu?
Anyway, with my DriverackPX set at +4dB(pro level), and the mixer just clipping, I had the DriveRackPX input meter just clipping. Backing off my master fader to 0, that put my mixer meter bouncing into the 2nd yellow (+6), and the DriveRackPX bouncing nicely into the only yellow on the input meter, also +6.
I assume that is all good?
Yes, but there is really no point to setting the gain for every input channel using the pink noise, because again...the gain level of the pink noise source may vary from, for example, the gain level of a microphone. You will still have to do a per channel gain level when you set up at the venue for each channel. Or you can do it ahead of time at home...but my point is, each channel will vary depending on the source. It would seem to me the pink noise exercise is mainly to get to unity between the mixer/DriveRackPX and the DriveRackPX/Speakers. Correct?
Understood. But those are all that matter for the purpose of the DriveRackPX. The only other outputs are the monitors, and since they do not go through the DRPX, I would just make sure that the Aux Send is at unity with my 231 GEQ and that it, in turn, is not driving the powered monitor speakers to clipping.
Yep. I am good on that. With channel and master faders at 0, the DRPX input Headroom is at 12dB.
On the same channel you set up at -unity-, set the aux and aux master output knobs to -0- and connect that output to the EQ. Adjust the input of the EQ to -0- on the EQ's meter. Ring the monitor out and re-adjust the EQ's input to -0- to compensate for the cuts.
Powered speakers will typically -unity- out about 12 oclock. Keep in mind most powered speakers do no clip, they limit. Semantics, I guess, but still best to avoid either.
What I do (situation may well be different that you), is I will play a CD (but paused) and adjust the speaker's input to an acceptable hiss for the situation. For me that is 10-11 o'clock. You will have to make the final call on whether you what the speakers to limits before, at the same time, or after you reach the "max output" you want from the board.
