Useable with Bose Panaray
We have an older Bose Panaray system. (Yes I know please save all slams on Bose.) It is in a mediam sized very wide sanctuary. Permanent install.
Will the Driverack PA+ work with this type of system? I figure I would need to put it inline before the Panaray controller. We would like to use it for baseline EQ'ing.
The Bose system is not listed in the Speaker list.
  • There really aren't any presets for any fullrange speakers. If you peruse the presets for any of the (except those that require active crossovers) fullrange speakers. The controller for the bose panaray is likely needed as there probably isn't enough processing onboard for that purpose, but the DRAP+ should work great as an EQ processor.
