PA with EV 2x ELX118 and 2x Maste Audio M15 H
Hello,
i could use some help with some settings for my driverack PA.
I have:
2 Crown XLS 802 Amps
2 EV Live X ELX 118 Subs (passive)
2 Master Audio M15 H Tops.
I have set the Crossover LPF at 100 HZ and the HPF also for the tops.
I also edit some EQ settings for a better sound. Like putting some more DB in the settings around the 100 HZ.
it al sounds pretty well, but i think there is more to do with the the EV (Bass).
Does someone has experience with this combination or speakers with the PA?
And is it usefull to use the Limiter/Compresser? if yes what could i do?
Greets,
Francisco
I have:
Greets,
Francisco
