Can I have the full range signal going out the LO MID HI?
Hello,
I use a DRPA+ with 2 full range EV SX300E speakers - no subs yet. I only use the HI outs. Is there any way I can make the full range signal appear at the MID and LO outs as well please?
  • Set up a 1 (or 2 for stereo) x 6. In other words, in the wizard set-up process select "custom" "bi-amp" "with subs". This routes highs to hi, mids to mid, and lows to low. Now go into the x-over section and simply open up the filters' bandwidth to be "full range". You'll have HPFs on all outputs, and LPFs on L & M (not hi).
